03-20-2009 07:24 AM
Is it possible with LabView to show a graph only if a certain button is pushed?
I'd like to make diagram with several measurement point, displayed as numbers for a given time. If one is ineterested in the time-dependency it should be possible to fade in the graph.
Is this possible with LabView?
Thanks for helping.
03-20-2009 07:40 AM
03-20-2009 07:44 AM - edited 03-20-2009 07:45 AM
I'm not sure if you want to gradually fade in the visablility of the whole graph or want the traces to fade out like they did on old Storage Scopes.
If it is the latter see the attached that used to work in LV 7.1.
Ben
