extracting the values from array
I am trying to extract the data from a com port. I have made the for loop to decode the read  instruction word from the device. i now want to split the instruction word as i know first few bytes contain values that are of use to me. i read it into an array and now i am trying to extract the values from initial bytes of array. i have a example snipe that i can refer to. it has these two particular elements in example vi that i am not able to recognise. can someone help me what exactly these elements are? i have attached a snipe encircling both.
(1,343 Views)
Accepted by Ahraar
The larger one is Index Array and the other one is Concatenate Strings.
If you'll require further help, please attach your VI.
(1,336 Views)
