‎07-14-2005 05:24 PM
‎07-15-2005 12:45 PM
This is most likely related to the Windows update you recently installed on your computers. The cause of this lies in the registry settings for Windows, and not with LabVIEW itself. Editing the appropriate registry setting will solve this problem, but BEWARE! Take extreme caution when editing any registry settings. You may make changes that cannot be reversed and could force you to reinstall your operating system from scratch. National Instruments does NOT support this option.
If erasing WindowsVolume from the destination directory is indeed too much trouble, then (for your information) consider changing the following registry entry as indicated:
Key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\FileSystem
Entry: NtfsDisable8dot3NameCreation=0
National Instruments is working to fix this issue in future versions of LabVIEW without requiring any editing of the registry.
‎07-15-2005 01:35 PM
