Problems with a xy graph in labview 7.0
Ok, i have a problem with gettting the xy graph to plot two points when i send it data from a daq assistant.  I merge the two signals together and send it into the input of the xy graph but it always plots only one point.  It indicates on the block diagram that it receives two points to plot but still only plots one point.  If anyone has advice, please share.
(3,289 Views)
Your description is insufficient to troubleshoot the problem, could you attach a simple example. (Please replace your DAQ portion with diagram constants containing typical data).
(3,283 Views)
I know this sounds asinine, but have you set the xy graph to display more than one plot?  Right click->properties->appearance->plots shown.
I have made that mistake before and it was very frustrating until I realized I had forgotten to tell the graph how many plots to show...
(3,274 Views)
Yes, i did that same thing, thanks.
(3,262 Views)
Hi Nick,
What do you mean? You did the same mistake and now it works, or you tried that too and it still doesn't work?
I don't think I'm the only one that didn't get the meaning of your reply, so please let us know if you need more help, thanks.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(3,244 Views)
Yes, i made the same mistake and now it works.
(3,222 Views)
