12-14-2011 04:58 PM
When I open up an VI, this VI calls to other VIs in a hierarchy structure. Is it possible to output the entire hierarchy tree of VIs into a separate directory so I don't have to manually locate them one by one?
12-14-2011 05:14 PM
File->Save As... and select the "Duplicate hierarchy to new location" option.
12-15-2011 05:38 PM
it returns "labview: generic file IO error" without any codes but the hierachy is showing all the VIs just fine. I don't know why it won't export them all.
12-15-2011 06:17 PM
Haven't seen that error in a while... are you trying to save to a network drive? Does it happen regardless of the target directory? I'm not sure I can help with a solution, just tossing out questions in the hope that one of them might provide a clue as to the reason for the error. Do any files get saved, or it happens immediately?
12-16-2011 10:06 AM
no just local drive
it somehow exported half of the tree, the other half is still missing.
12-16-2011 12:02 PM
oh I got it, the path was too long....it would be nicer if it tells us but it didn't. Also, once I converted the xcontrol to ctrl and use it, it jacks everything up. That was a nightmare having to fix all the broken links because it refuses to let me export the xcontrol as the same name it has in memory. So when I change it to a different name, it exports fine but when I run the VIs, it refuses to load the new xcontrol file name.... oh well.
