exe file that access hardware using in/out port is working with win98(labview4.0) but the same exe is not accessing hardware for xp2000(labview8.5)
I have no source code for the server96.exe. Do tell me possible errors and possibilities to make it work. Change file extention ini with exe
Thanks and Best regards
timmy
(2,335 Views)
I have heard that NASA has lost the design documents for the Staturn 5 booster and the trip to the moon would have to be completely re-engineered.
The souce code can not be pulled from the exe.
If you have no source code you have two options.
1) maintain the app on its original OS with the exe you have.
OR
2) Carefully document all it does now and re-write it.
I hope I am wrong.
Ben
(2,326 Views)
