excel file to text in hex format 16 places per row
I have some data in an excel file that needs to be converted and arranged into 16 columns of hex text
Message 1 of 20
(2,953 Views)
Hi R,
And what is the problem?
Should we help you on creating some Excel/VBA macros?
Message 2 of 20
(2,936 Views)
Which ever is easier I guess. I was trying to do it in LabView. Maybe I should rethink it and do it in Excel. Thank you.
Message 3 of 20
(2,927 Views)
What is "hex text"? Very ambiguous and completely uninformative!
So you have an excel file with text formatted cells containing one or two numeric digits (that for all practical purpose could already be hex formatted, who knows!!!) in variable length rows. (but many more that 16 columns!) How should the values be reshaped into 16 columns? What does the problem have to do with LabVIEW?
Message 4 of 20
(2,926 Views)
60 20 00 40 60 60 40 00 20 20 00 00 20 20 00 00 20 20 00 40 60 60 40 00 20 20 00 00 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 40 60 60 40 40 60 60 40 00 20 20 00 40 60 60 40 00 20 20 00 00 20 20 00 00 20 20 00 40 60 60 40 00 20 20 00 00 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 00 00 40 60 60 40 00 20 20 00 00 20 20 00 40 60 60 40 00 20 20 00 00 20 20 00 00 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 40 60 60 40 00 20 20 00 00 20 20 00 00 00 00 40 60 60 40 00 20 20 00 00 00 20 00 00 20 20 00 40 60 60 40 00 20 20 00 00 00 40 60 60 40 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 40 60 60 40 00 20 20 00 00 20 20 00 00 20 20 00 40 60 60 40 00 20 20 00 00 20 20 00 00 20 20 00 40 60 60 40 00 20 20 00 00 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 40 60 60 40 00 20 20 00 00 20 20 00 40 60 60 40 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 40 60 60 40 00 20 20 00 40 60 60 40 00 20 20 00 00 20 20 00 00 20 20 00 40 60 60 40 00 20 20 00 00 00 00 20 20 00 00 00 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 40 60 60 40 40 60 60 40 00 20 20 00 40 60 60 40 00 20 20 00 00 20 20 00 00 20 20 00 40 60 60 40 00 20 20 00 00 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 60 20 00 00 20 20 00 00 20 20 00 40 60 60 40 00 20 20 00 00 20 20 00 40 60 60 40 00 20 20 00 00 20 20 00 00 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 40 60 60 40 40 60 60 40 00 20 20 00 40 60 60 40 00 20 20 00 00 20 20 00 00 20 20 00 40 60 60 40 00 20 20 00 00 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00 00 20 20 00
Message 5 of 20
(2,870 Views)
I have not looked at your file, but there are conversion functions in excel that might help.
Good luck.
Message 6 of 20
(2,912 Views)
If posting a bunch of numbers, provide some explanation!
What are we supposed to do with this? (e.g. scan as a 1D numeric array assuming it is decimally formatted (only digits 0..9), then reshape to a 2D array with 16 columns (add padding if necesaary) and format in some kind of hexadecimal format (characters 0..F) with certain field (tab, space, etc.) and row delimiters (e.g. \n)).
Please be very (very!!!) specific! (e.g. you show 627 elements, which is not divisible by 16)
Message 7 of 20
(2,868 Views)
I started, but something has changed on the website and I need to get used to the new format. That said. I have these numbers in Excel, let's just say 60 40 0 60 0 0 40 60 40 0 60 0 0 40 60 40 0 60 0 0 40 60 40 0 60 0 0 40 60 40 0 60 0 0 40. I want them to be like this. 60 40 00 60 00 00 40 60 40 00 60 00 00 40 60 40 00 60 00 00 40 60 40 00 60 00 00 40 60 40 00 60 00 00 40
Message 8 of 20
(2,859 Views)
Here's one possible interpretation of the problem. You can easily change the various formats depending on what they are.
(Maybe the original is already hex formatted?)
Message 9 of 20
(2,845 Views)
Maybe like this?
Message 10 of 20
(2,838 Views)
