LabVIEW FPGA Memory Compile Time Constants
Hi All,
I am trying to circumvent the limitation that LabVIEW FPGA doesn't support 2D Arrays, by leveraging memory. Right now, I have to set the depth of the memory manually, such that when I change the 2D Array dimensions, I need to change my #rows constant, #columns constant, and #elements constant (the memory size). I am looking for a method that allows me to set the memory size based on compile time constants.
Does anyone know anything?
Tom
Message 1 of 8
(3,186 Views)
Hi Tom,
Can you explain the term "compile time constants"?
What is the difference of "compile time constants" to "constants in your code, evaluated when compiling the FPGA code"?
Message 2 of 8
(3,140 Views)
Thanks for the reply.
I guess there really isn't a difference in this context.
I can't find a method to create a Memory using Block Diagram defined size, so I am hoping that there is some other nob I can spin at the project level. Perhaps, I can implement a Conditional Disable Structure with project defined symbols.
Another example of a similar problem is that the Array Size of a Fixed Size Array is not a constant according to the compiler.
Tom
Message 3 of 8
(3,127 Views)
Hi Tom,
A memory block is created and defined in the project explorer. You can only use that memory block in your FPGA VI…
Which memory block sizes are we talking about?
The result of the ArraySize function is a value (in a wire). Why should it be a "constant"?
Message 4 of 8
(3,124 Views)
I agree that memory blocks are created and defined in the project explorer. This is the fundamental problem that I am trying to circumvent. The size of my memory block is a function of the #row and #columns of my matrix. Therefore, I would like to set the size of my memory block based on an equation that is resolvable at compile. This will make my API much more flexible.
I disagree with your argument that the size of a fixed array shouldn't be constant because it travels on a wire. All constants in LabVIEW still travel on wires. For comparison, this is how you can implement the behavior I would like in C. (https://stackoverflow.com/questions/3388656/how-to-determine-the-length-of-an-array-at-compile-time)
At this point, I guess these are more feature requests than anything else. I am just find it very difficult to implement good design practices in LabVIEW FPGA, given the limitations.
Another example is that there is no function that can initialize a Fixed Size Array.
Tom
Message 5 of 8
(3,119 Views)
Hi Tom,
Nice ideas: did you post them in the FPGA-IdeaExchange?
Again: which memory block sizes do we speak about?
Which API functions are we talking about?
Can you attach an example implementation of the desired API?
I guess that C code will not create code for a FPGA target?
I still don't get the point of reading the size of a FixedSizeArray, create by you at edit time!? You already know its size, don't you?
Simply place an array constant in your FPGA code and set its size: now you have your array initialized…
Message 6 of 8
(3,117 Views)
I think Tom would like is to define the size of his FPGA memory by e.g. a "conditional diable symbol" before he runs his FPGA compilation...
Not sure if that is possible or not...
Regards, Jens
Kudos are welcome...
Message 7 of 8
(3,107 Views)
This would indeed be a very nice feature.
Message 8 of 8
(2,485 Views)
