excel export
Accepted by snuk
Hi snuk,
see this.
Mike
Message 11 of 20
(3,218 Views)
it's good as it is but...just wondering!
no it is defenitely not good and u need to append the data to the same file.
Message 12 of 20
(3,215 Views)
Mike's example makes more sense isnt it?
Message 13 of 20
(3,209 Views)
yes but I can't find that block!!! what's the .lib???
Message 14 of 20
(3,201 Views)
... it's "build Array"
Mike
Message 15 of 20
(3,200 Views)
Message 16 of 20
(3,195 Views)
mike...your exemple is good but works only for the date... I'll try combining it with muks'! because I need the time also!
Message 17 of 20
(3,190 Views)
Hi snuk,
you should read the description of the "Format Date/Time function". You can add more format codes.
Mike
Message 18 of 20
(3,187 Views)
It's DONE!
THANK YOU GUYS!!!
Message 19 of 20
(3,184 Views)
Glad to help!!!!!!!!!!!:smileywink:
Message 20 of 20
(3,150 Views)
