excel and word application in automation open vi
@aputman wrote:
I don't know if ActiveX is installed by default but there are other programmers tools that are not installed by default.  So my solution is to just install everything.  Smiley Wink
Ha, ha, ha (as my son would say).  I install "the bare minimum" (only the tools I'm reasonably sure I'll use).  I do install the VBA tools, however, and could imagine that they might be necessary ...  [My Win 7 machine does have the Objects required].
Message 11 of 13
(1,479 Views)
Do you have this file:
C:\Program Files (x86)\Microsoft Office\Office1x\XLxEN32.OLB?
and this one for Word:
C:\Program Files (x86)\Microsoft Office\Office1x\MSWORD.OLB
If you do, you can manually create ActiveX object from the file.
George Zou
Message 12 of 13
(1,468 Views)
Hi
So I was facing the same problem with not finding the excel activeX class in labview. So here's the solution I found.
Add Automation Reference on front panel> Right click it> Select ActiveX Class>Browse>Browse (Again) >
and select these files according to your office version. Excel does not have .OLB files instead it uses executable for creating objects.
Office 2013:
"C:\Program Files (x86)\Microsoft Office\Office15\EXCEL.EXE"
Office 2016:
"C:\Program Files (x86)\Microsoft Office\root\Office16\EXCEL.EXE"
It will add all the methods and properties of excel class automatically. Don't forget to switch to "All Files" while browsing.
Regards
Rishav
Message 13 of 13
(880 Views)
