Showing results forĀ
Search instead forĀ
Did you mean:Ā
event structure
while am using event structure triggered by a boolean push button during running the program when i press the button the whole execution will stop
(2,817 Views)
So?  What's the problem?  It is doing what you told it to do.  Did you want it to do something else?  What?
If you refuse to show us what you did (by attaching the VI, not a picture of the VI), then spending some time with the LabVIEW Tutorials listed on the first page of this Forum should teach you enough to enable you to "Fix it yourself".
(2,782 Views)
This is not sufficient information to troubleshoot. Can you attach a simplified version of your VI?
(Typically, symptoms like this is caused by poor architecture due to misunderstandings how dataflow works. One guess would be an event structure unreachable by dataflow (buried inside a case structure, buried inside an sequence frame that has already passed, etc.. Events lock the front panel (by default) until the event completes so if the event structure cannot be reached or cannot complete, you get a permanent UI lockup.)
(2,742 Views)
My guess is on an infinite loop inside the event and 'Lock front panel' as event setting.
Or it's on row 43 of the code.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,727 Views)
