How to convert decimal string array to binary string array
Hi
Does anyone know how to covert the arrays
16        00010110
80   to  10000000
0B        00001011
30        00110000
Regards
Patrick
Message 1 of 9
(4,913 Views)
Yes, I (and many other readers of this Forum) do.
Why don't you try to figure it out for yourself?  There are Tutorials mentioned on the first page of this Forum.  Since you are dealing with Strings, examine the functions on the Strings Palette.
Message 2 of 9
(4,863 Views)
If your input string array is on hex display and one byte per element, you can try to do something like this (for each element):
If input array is on normal display you have to replace the Unflatten From String function with Hexadecimal String To Number
Lucian
CLA
Message 3 of 9
(4,848 Views)
@Patrick0830 wrote:
Hi
16        00010110
80   to  10000000
0B        00001011
30        00110000
First of all, the left side is NOT a "decimal" string (characters 0..9), but a hexadecimal string (characters 0..F). Big difference! You have two nibbles, so you are dealing with a single byte, which can be represented as 8 binary characters (0..1). Is it never more that two hex characters on the left? Does the left side start out as a string array or is it derived from a U8 numeric array?
Is this a programming exercise or a process that occurs often and should be as fast as possible?
What have you tried? Once you have code for all 256 possible combinations, you could create a lookup table, right?
You could even just leave it as a U8 array and just change the display format, right?
Message 4 of 9
(4,837 Views)
One possibility?
Message 5 of 9
(4,834 Views)
Accepted by topic author Patrick0830
Another interpretation (all strings are normal display).
Message 6 of 9
(4,832 Views)
It works well, thanks.
Message 7 of 9
(4,783 Views)
Thanks for your suggestion, I am a beginner and have spent over 2 days to figure out how to do it, so I posted here for help.
Regards
Patrick
Message 8 of 9
(4,780 Views)
Thanks, let me have a try.
Regards
Patrick
Message 9 of 9
(4,779 Views)
