eval formula node vi cannot work with simple math functions
Hi I have problem using eval formula node.
And it produces error.
The formula is AI0=AI0-AI6; AI1=AI1-AI6; AI2=AI2-AI6; AI3=AI3-AI6; AI4=AI4-AI6; AI5=AI5-AI6;
Pls see the attached. I am using LV 7.1
Pls help. Will be grateful for your help
Clement
(3,397 Views)
Accepted by astroboy
See if this document explains your problem.
The problem seems to be the names you gave to your variables.
I found this document after doing a search on the forums for the error code 23083.
(3,381 Views)
Yes, the problem are your variable names.
Can you give us a bit of background why you want to do such a complicated and inefficient method for such a simple operation. The same could be done trivally with exactly three primitives (index array, array subset, subtract) and no purple at all.
(3,371 Views)
Hi Raven Fans and Altenbach
Thanks now I understand.
Clement
(3,334 Views)
