08-11-2009 10:30 PM
Hi I have problem using eval formula node.
And it produces error.
The formula is AI0=AI0-AI6; AI1=AI1-AI6; AI2=AI2-AI6; AI3=AI3-AI6; AI4=AI4-AI6; AI5=AI5-AI6;
Pls see the attached. I am using LV 7.1
Pls help. Will be grateful for your help
Clement
08-11-2009 11:22 PM
See if this document explains your problem.
The problem seems to be the names you gave to your variables.
I found this document after doing a search on the forums for the error code 23083.
08-12-2009 12:25 AM
Yes, the problem are your variable names.
Can you give us a bit of background why you want to do such a complicated and inefficient method for such a simple operation. The same could be done trivally with exactly three primitives (index array, array subset, subtract) and no purple at all.
08-13-2009 02:26 AM
Hi Raven Fans and Altenbach
Thanks now I understand.
Clement
