error installation labview 8.5
Hi guys...
I have downloaded the labVIEW  8.5 from ni.com.after finish, i extract this file WinZip Self_Extractor.In the middle of work, i can't install it.it is bcoz the error like this "ZIP damaged: file C:\National Instruments Downloads\LabVIEW\8.5\Products\LabVIEW\vi.lib.msi\mib.cab:Bad CRC. Possible cause:file transfor error"
and then, i try the other way like using winRAR to achieve it 1st.and then after i extract it again, the error occurs something like that ....
!   C:\Downloads\labview_85.exe: CRC failed in Products\LabVIEW\vi.lib.msi\mib.cab. The file is corrupt
!   C:\Downloads\labview_85.exe: CRC failed in Products\LabVIEW_FF_Runtime_Engine_85\lv85ffrte\mib.cab. The file is corrupt
!   C:\Downloads\labview_85.exe: CRC failed in Products\LabVIEW_HelpChm_85\lvhelp85\mib.cab. The file is corrupt
!   C:\Downloads\labview_85.exe: CRC failed in Products\LabVIEW_Help_85EN\LVHelp.msi\mib.cab. The file is corrupt
!   C:\Downloads\labview_85.exe: CRC failed in Products\LabVIEW_MeasAppsChm_85\MeasAppChm85\mib.cab. The file is corrupt
!   C:\Downloads\labview_85.exe: CRC failed in Products\LabVIEW_Runtime_Engine_85\lv85rte\lv85runtime.msi. The file is corrupt
!   C:\Downloads\labview_85.exe: CRC failed in Products\NI-USI\NI-USI.msi. The file is corrupt
!   C:\Downloads\labview_85.exe: CRC failed in Products\NI_Logos\logos490\logos.msi. The file is corrupt
!   C:\Downloads\labview_85.exe: CRC failed in Products\Variable_Engine\ve210\mib.cab. The file is corrupt
!   C:\Downloads\labview_85.exe: CRC failed in Products\Variable_Engine\ve210\nive.msi. The file is corrupt
!   C:\Downloads\labview_85.exe: CRC failed in Products\Variable_Engine_LVSupport_85\niVELVSupp850\VarEngineLVSupp.msi. The file is corrupt
!   C:\Downloads\labview_85.exe: CRC failed in Products\VC2005MSMs\VC2005MSMs\VC2005MSMs_x86.msi. The file is corrupt
So, I wonder that this 8.5 didn't support windows xp or else....so i hope u guys can reply me with the feeback...thank u very much
Message 1 of 16
(10,745 Views)
I successfully downloaded it on two different computers and installed with no problem running on XP.
I used firefox to download it, IE seems to get  a connection reset fairly often with large files.  Thus, you do not get the entire file.
Paul
Message 2 of 16
(10,738 Views)
Hi Takimi,
It sounds like your file was corrupt. Like Stradis mentioned, try using Firefox or other download manager such as FlashGet to download the file.
LabVIEW 8.5 does support Windows XP, so you shouldn't have problems there.
Yi Y.
http://www.ni.com/support
Message 3 of 16
(10,702 Views)
Hello Stradis.....
thanks 4 ur advise....after following ur instruction, now i can download it using firefox without any errors...thank u very much...
Message 4 of 16
(10,666 Views)
Hi Yi Y....
thank you for your suggestion. actually, I was using firefox already..and have installed the flashget. for the 1st time using flashget,the error occurs like before. after that, I try using free download manager... but it's dissapoint me. It seems to get a connection reset fairly often with large files. so, 4 the forth times, i try again with flashget..finally ..This mornin'...i can extract the files and install it normally.. its sound like funny right..but thank u very much again...
Message 5 of 16
(10,661 Views)
During instalation of Labview 8.5 from an evaluation copy CD, I got Error 1335, stating that Mib.cab was corrupt.
The installation program also asks for a driver CD. After this the rest of the instalation fails.
My default browser is allready Firefox if this would matter at all when installing from CD.
How can I solve this problem?
RB
Message 6 of 16
(10,314 Views)
RB
PietPuk,
It is possible you received a corrupt install CD. Have you tried to install this software on another computer?
Mark
NI App Software R&D
Message 7 of 16
(10,296 Views)
No, and actually I don't have another computer available to try this. Of course it is possible that my installation CD has an error on it, but then I would't like to know how to compensate. What I can see is that it is an original evaluation CD which the company who asked me to practise working with Labview received from National Instruments. (Because of the label on the CD and protecting cover.) So I don't know how likely it would be that one of those would contain a corrupt file. Or what else could explain the error message. Or the fact that each time my computer starts an error message appears stating that a fatal error occurred in National Instruments and it will be shut down. Probably I might need to uninstall it (even though installation failed) before being able to get it working. But would it be possible to get an intact verion of the corrupt file ? RB
Message 8 of 16
(10,282 Views)
I recommend downloading the evaluation version of LabVIEW from our website,  which can be found here.
Mark
NI App Software R&D
Message 9 of 16
(10,263 Views)
When Installing after downloading the file from the location you suggested installation from this version results in exactly the same error message and fails likewise. Do you have any idea what could be the cause of this? RB
Message 10 of 16
(10,236 Views)
