Pressure versus Volume graph
Hi Everyone,
On my system i require a graph of pressure vs volume.
I have tried merging the data from the my pressure transducer and my crank angle encoder (volume) but i end up with a graph showing the two different data streams.
How can i alter the information so that it gives me a graph of pressure vs volume instead of pressure and volume vs time?
I have struggled on this for a while now and i cant find a solution.
Please help me!
Alex
:mansad:
Message 1 of 14
(9,790 Views)
You can use the XY graph instead of the normal Waveform graph.
Vikas
Message 2 of 14
(9,787 Views)
Thanks Vikas,
I have linked up the XY graph express programme to 2 sine signals but cannot get the graph to show any points. The axis moves up and down which corresponds to the sine graph, but no line is shown? I have tried playing with the options but it still shows nothing.
Do I need to change the data type? Why is this so hard?
Alex
Message 3 of 14
(9,746 Views)
Hi Alex,
can you show us the vi with the xy graph?
Mike
Message 4 of 14
(9,739 Views)
Hi Mike,
Here you are.
Alex
Message 5 of 14
(9,736 Views)
Hi Alex,
I assume you are using the sinusoidal signals for experimentation. See the attached VIs - they should give you some idea of the usage.
Vikas
Message 6 of 14
(9,734 Views)
Thanks Viskas,
Can you put these into an earlier version of Labview? Ive only got 8.2!
Alex
Message 7 of 14
(9,730 Views)
Hi Alex,
here is your vi with some changes.
Mike
Message Edited by MikeS81 on 02-29-2008 01:08 PM
Message 8 of 14
(9,727 Views)
Hi Alex,
Here are 8.2 versions..
Vikas
Message 9 of 14
(9,724 Views)
Mike thats brilliant. Thanks.
I tried to get the data into the correct array/cluster forms for the XY graph but I just couldnt find the right ones.
Thanks a lot.
Alex
Message 10 of 14
(9,718 Views)
