erreur lors de compilation de l' FPGA
bonjour,
Voici l'erreur que j'obtiens quand je veux compiler mon programme FPGA
LabVIEW FPGA: La compilation a échoué à cause d'une erreur Xilinx.
Details:
ERROR:smileytongue:ack:2310 - Too many comps of type "SLICE" found to fit this device.
Design Summary:
Number of errors: 1
Number of warnings: 89
Logic Utilization:
Number of Slice Flip Flops: 7,963 out of 10,240 77%
Number of 4 input LUTs: 10,607 out of 10,240 103% (OVERMAPPED)
Logic Distribution:
Number of occupied Slices: 5,523 out of 5,120 107% (OVERMAPPED)
Number of Slices containing only related logic: 4,143 out of 5,523 75%
Number of Slices containing unrelated logic: 1,380 out of 5,523 24%
*See NOTES below for an explanation of the effects of unrelated logic.
Total Number of 4 input LUTs: 11,028 out of 10,240 107% (OVERMAPPED)
Number used as logic: 10,454
Number used as a route-thru: 421
Number used as 16x1 RAMs: 70
Number used as Shift registers: 83
Number of bonded IOBs: 90 out of 324 27%
IOB Flip Flops: 97
Number of MULT18X18s: 38 out of 40 95%
Number of BUFGMUXs: 2 out of 16 12%
Peak Memory Usage: 359 MB
Total REAL time to MAP completion: 19 secs
Total CPU time to MAP completion: 19
J'ai essayé de reduire mon programme le maximum mais l'erreur revien a chaque fois que j'ajoute une nouvelle variable
voici une capture ecran du programme
merci d'avance :smileyhappy:
(3,110 Views)
Accepted by CrisSTine01
Hi ramlus,
you know you posted in the English section of the forum?
To your problem: you have too much code to fit into your FPGA…
On your code:
- Why do you convert readings to SGL in the first place, when you have I16 indicators?
- Why don't you use FXP indicators?
- Why don't you scale the values in the RT host?
- Why don't you create an array of all measurement values and use just one array indicator to forward values to your RT host?
(3,098 Views)
Hello thank you for you answer
Sorry for posting in the wrong section I didn't pay attention,
I replaced all the SGL convertors to FXP convertors , it works 🙂
could you please explain to me how to scale the values in the RT host ??
(3,092 Views)
Hi Ramlus,
you just send the raw FXP values to your RT host and then you "multiply by 1000" in the RT host VI - easy as it is…
(3,089 Views)
Thank you 😄
(3,081 Views)
