Hi All,
I am trying to write a remote .NET client using evaluation version of
LabView 7.0 Express.
I have the following description for what i am doing: Using the .NET
palette, I added a constructor whose output is wired to
an Invoke node with a method Connect, which returns an object. This object's
reference is being wired to the input of another invoke node (the moment i
connect it, it displays the correct Class name for this object). But, when i
run the .vi, i am seeing err (1055) coming out of the second invoke node
(err 1055 says that the object reference is invalid.) i am totally at loss
as to what is happening here. I appreciate any help that i can get.
(I had the err (1175) which i could remove after adding the required dll in
the path)
Thanks in advance,
raghav.
