err (1055) using .net 1.0
Hi All,
I am trying to write a remote .NET client using evaluation version of
LabView 7.0 Express.
I have the following description for what i am doing: Using the .NET
palette, I added a constructor whose output is wired to
an Invoke node with a method Connect, which returns an object. This object's
reference is being wired to the input of another invoke node (the moment i
connect it, it displays the correct Class name for this object). But, when i
run the .vi, i am seeing err (1055) coming out of the second invoke node
(err 1055 says that the object reference is invalid.) i am totally at loss
as to what is happening here. I appreciate any help that i can get.
(I had the err (1175) which i could remove after adding the required dll in
the path)
Thanks in advance,
raghav.
Message 1 of 10
(3,589 Views)
Do you have some sample code that I could try out on my machine? Is this your own assembly or are you calling one of the built in functions?
Let me know
Bilal Durrani
NI
Bilal Durrani
NI
Message 2 of 10
(3,589 Views)
"bilalD" wrote in message
news:5065000000050000003B220100-1042324653000@exchange.ni.com...
> functions?
> Let me know
> Bilal Durrani
> NI
Thank you for the reply.
It is our assembly that i am using.
i know that describing the problem in more detail will not help, but
i cannot send a sample right now.
will be glad if you could please mail me at nr@tek.com?
Thanks a lot,
raghav.
Message 3 of 10
(3,589 Views)
you can email in the problem to support@ni.com, just add my name in the subject line.
Bilal
Bilal Durrani
NI
Message 4 of 10
(3,589 Views)
Thank you once again Bilal.
I shall mail you.
raghav.
news:50650000000500000049220100-1042324653000@exchange.ni.com...
> the subject line.
> Thanks
> Bilal
Message 5 of 10
(3,589 Views)
Hi Bilal,
I had mailed you on the 17th of September. I just wanted to see if you could
have a look at that mail.
Thanks for the help,
raghav.
> the subject line.
> Thanks
> Bilal
Message 6 of 10
(3,589 Views)
Hi Bilal,
I have the exact same problem that this guy has I can send you some sample code if you needed. I am hoping you have an aswer.
Message 7 of 10
(3,589 Views)
Hello
Sorry I didnt check this post for a while, I didnt get an email for this, I was wondering what happened. Try using this link to send it in. Use email as communication method Usually you get a notification telling you that support has received an email. Kinda curious if you got such a notification
Bilal Durrani
NI
Message 8 of 10
(3,589 Views)
news:506500000005000000A8240100-1042324653000@exchange.ni.com...
> Hello
> href="http://sine.ni.com/apps/we/niae_asc.main">link
to send it
Hi Bilal,
Thank you very much for the reply.
i have sent a reply to your mail. This time i have attached the file
correctly, sorry that i did not do it correctly the last time.
Thank you once again,
raghav.
Message 9 of 10
(3,589 Views)
I have exactly same problem. I added DLL's to GAC so that .net DLL's can be shared by different applications such as LV and TS. But, I still get the 1055 error. If I call the DLL functions in pure TS or LV environment there is no error. I think there is a problem sharing between LV and TS.
Message 10 of 10
(3,589 Views)
