State Machine and producer consumer design patterns
Hi!
In my application I am using state machine(for top level VI) and producer consumer(for subVIs) design patterns throught out.
If there is no activity on the front panel for 1min then the ideal state is invoked. Following are the situation of the ideal state:
1. It checks for any hardware present on the network . If no hardware is found on the network within 1 min then the application and LabVIEW exits.
2. While the ideal state checks for the hardware, and user clicks on any front panel button then it should exit the ideal state. The control
should be in the respective button state.
I am able to achive the point#1 mentioned above but could not get the point #2 to work. I am including the snap shot of
the state machine(default case) and prouducer consumer(deafualt state).
Each screen has the concept of the ideal state. The only additional step in the subVIs is that when the ideal state is reached and the time has expired then it will close the subVIfront panel.It will go to the exit state of the Main(top level) VI. Thus closing the application and quitting LabVIEW.
Any ideas or suggestions. Will multithreading and notifiers help?
TIA
Rachana
Message 1 of 1
(2,425 Views)
