empty folder
Hi Labview experts,
i been noticing my Delete folder function is not working properly when the folder is not emptied.
Can someone show me how to empty out a folder or delete a folder with files in it?
Message Edited by krispiekream on 01-13-2010 03:17 PM
Krispiekream
Message 1 of 10
(7,923 Views)
Do you have the 'entire hierarchy' set to True?
Message 2 of 10
(7,916 Views)
oh boy, i am using labview 7.0 and i dont think it has that.
labview 8.5 do.
Krispiekream
Message 3 of 10
(7,909 Views)
OpenG has a recursive delete that you can use in 7.0.
Message 4 of 10
(7,896 Views)
Unfornately, installing openG could be a problem when there is not internet on the testing station.
Are there any other options?
Krispiekream
Message 5 of 10
(7,875 Views)
Install it on a PC that does have an internet connection and copy over the OpenG library files in whatever way you are able to get files onto the disconnected PC.
Message 6 of 10
(7,865 Views)
in seven you can list the folders contents - delete all listed files before you delete the folder. If sub directory folders are also listed you also need to delete these (and there contents) first
David
www.controlsoftwaresolutions.com
Message 7 of 10
(7,835 Views)
also check that the folder whichyou want to delete is having the proper permission.
Also there is a chance that one  or more of these files (or the refnum) might be open when you are trying to delete the folder itself.
Guru (CLA)
Message 8 of 10
(7,815 Views)
Accepted by krispiekream
Hey krispiekream
In regards to your original request. Here is a simple routine you could use to delete all the files in a folder and then delete the folder itself.
Hope this helps.
-Ben
WaterlooLabs
Message 9 of 10
(7,797 Views)
thank works.
thank you so much!
Krispiekream
Message 10 of 10
(7,774 Views)
