Minimum symbol rate for RFSG
Dear all,
I am using the RFSG (5610 up converter).As per my requirement i want to use lower symbol rate (50 to 9600).Is it
possible to generate lower symbol rates.
(3,036 Views)
It would help if you would define your question better. As you stated "5610 upconverter" just translates IF to a higher frequency carrier. It really has nothing to do with symbol rates. What exactly do you mean by "symbol rate"? Are you talking about IQ rate? What version of LabVIEW are you using? What hardware are you using? What are you trying to accomplish? Have you looked in the example finder? What does your code look like?
Hope this helps to define your query.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,011 Views)
Also, continuing from here, what is meant by feeding serial data to an RFSG? It'll be nice if you can give a proper description of what you're trying todo.
(2,995 Views)
