email HELP?
hi i've try to send email with gmail to ymail, but i've some trouble.
please help me
Message 1 of 8
(4,879 Views)
What version of LabVIEW you are using?
Go through all these posts and post if still you need some help.
Message 2 of 8
(4,871 Views)
labview 8.6
Message 3 of 8
(4,869 Views)
Message 4 of 8
(4,848 Views)
muks wrote:
See the attached vi
Works like a charm!
(Too bad I can only give 1 kudos per post)
Patrick Allen: FunctionalityUnlimited.ca
Message 5 of 8
(4,830 Views)
i've download your vi but it's still have same problem.
Message 6 of 8
(4,751 Views)
You will need to provide more information, such as which node is actually generating the error. Run the VI in debug mode with highlighting on. Identify which node is first generating the error. There are some nodes that do not have the error I/O wired. Please make sure to wire the error wires before running the VI.
Message 7 of 8
(4,728 Views)
Please attach your vi that you have wired.
Message 8 of 8
(4,688 Views)
