How to Drag and Move one pop up window through Lab view?
     How to drag and move one pop up window through Lab view?
    Ex-One VI is running comparing Two strings,suppose both string mismatch,one pop up will come as "MISMATCH"How to drag and move that window or VI.
With Regards
Dib
Message 1 of 14
(4,340 Views)
Put the mouse curser on the title bar and move the panel around. Being able to move the vi is the default behavior.
I'm assuming in sub vi properties, you checked "Show Front Panel When Called" and "Close Afterwards."
Message 2 of 14
(4,329 Views)
I want to do in Customize option.
Message 3 of 14
(4,318 Views)
hi,i got the solution,but how to hide the lab view symbol.anyway let me know.
Message 4 of 14
(4,316 Views)
There are lot of options.
1. Use a run time menu
2. In properties select- hide title bar.
Message 5 of 14
(4,300 Views)
Hi ,
       please give the detail solution regarding Drag and move,how to do that clearly,also i want to hide that Tool bar.After hiding the tool bar it should be dragged and moved properly.
Message 6 of 14
(4,291 Views)
HI,
      I want to replace that Lab view symbol on the title bar with my own image.,can it be possible?
With Regards
Dibya
Message 7 of 14
(4,273 Views)
Hi Dibya,
to replace the LabView symbol in the title bar you have to use your own icon for the executable...
Message 8 of 14
(4,271 Views)
Hi Dibya,
to drag/move a window without title bar you have to watch for mouse events (up/down/move) and then move the window using property nodes...
Message 9 of 14
(4,270 Views)
Hi GerdW,
Please explain clearly how to replace LabVIEW icon in the title bar.
Thanks.
Message Edited by vncontrols on 08-09-2009 01:53 AM
Message 10 of 14
(4,193 Views)
