editing single key value within ini file
Hello all, I have one .ini file I wanted to open the .ini file and change only one particular key value and save the file. I have tried doing it as a text file but not able to get perfect vi for .ini file. can someone please help me. In given file I have to change CMD="8" to CMD="6"
 [CMD_cmd3]
CMD = "8"
Timeout = "10"
any help will be accepted! Thanks for helping us to learn Labview
Message 1 of 11
(5,280 Views)
Accepted by LamarDavisss
LabVIEW has a set of VIs for working with ini-style files: Configuration File VIs. You find them in 'File I/O' palette.
It is as easy as open file, write key and close file.
Message 2 of 11
(5,266 Views)
Hi Lamar,
you can directly work with .ini files in LabVIEW so [CMD_cmd3] will be your section and CMD will be your key.
In Example Finder you can look up "Configuration (INI) File.lvproj", which explains the work with ini files nicely.
If you need to write your value in parenthesis, then change the data type of CMD Value to string and pass it to the Write Key.vi (it's polymorphic).
EDIT: oh, UliB was faster than me (at least it's good to know that we're giving consistent advises 😄 )
_______________________________________________________________
-Patrik
CLA || CTA
If it helps - Kudo it, if it answers - Mark As Solution
Message 3 of 11
(5,261 Views)
@Ajskrim wrote:
Hi Lamar,
Not to bring the hammer down on you, but this could've been made a LOT neater.  There is no reason to have wire bends all over the place and haphazardly placed block diagram constants.  Even if you were lazy, using the BD cleanup tool would've made a decent block diagram.  If you're going to post code as a solution, you should follow best LabVIEW practices.
Bill
CLD
(Mid-Level minion.)
Message 4 of 11
(5,234 Views)
Indeed, that is a very ugly piece of code 😄
Thanks for pointing this out, next time I'll try to do better job.
-Patrik
CLA || CTA
Message 5 of 11
(5,221 Views)
Guys.... sometimes you need to pay attention to the little things.
@lamar, when you edited your ini file with notepad you inadvertently changed the file name from
Test.ini. to
Test.ini.txt
So, test.ini never changed and the code still ran with the original settings.
"Should be" isn't "Is" -Jay
Message 6 of 11
(5,219 Views)
Pardon! got it will take care of it
Message 7 of 11
(5,215 Views)
Thats Awesome! Thank you so much for this vi. Now i got it where I was wrong.
Message 8 of 11
(5,214 Views)
Yes this is definitely good to go. Thank you so much for helping noob labview developer.
Message 9 of 11
(5,213 Views)
Test.ini. to
Test.ini.txt
Oh, well.  Everyone got a lesson in how to use the config VIs and some advice on LV best practices.  😄
Bill
CLD
(Mid-Level minion.)
Message 10 of 11
(5,160 Views)
