dynamic array to cluster creation
Is there a way that labview recognises the array size and automatically unbundle it into that many clusters as number of elements in the array?
PS. I am using labview 8.2
Labview 8.2
Learner
(4,217 Views)
No, clusters are fixed in size and can only be modified in edit mode.
Why do you even need clusters? Can't you keep it as an array?
(4,209 Views)
I need them to plot several variables on different graphs..
Like this one below..
Labview 8.2
Learner
(4,197 Views)
Something like this?
Message Edited by Jeff Bohrer on 05-01-2009 09:12 AM
"Should be" isn't "Is" -Jay
(4,187 Views)
Accepted by chravikumar
That would simply force you to use a default cluster of 9 elements. What if the array is more than 9?
@ravi:
You do not need to convert an array to a cluster and then unbundle the cluster to get the individual elements. Index Array is resizable. Better yet: use a for-loop with autoindexing. As to the actual graph that's being created I don't quite understand it. You are using the same X value with different Y values. That's just a vertical line. As altenbach likes to say, your code can be simplified to fit on a small stamp:
Message Edited by smercurio_fc on 05-01-2009 09:25 AM
(4,180 Views)
Yes smercurio,
 What u understood is right.. i shall try the method u suggested and let you know..
Ravi
Labview 8.2
Learner
(4,170 Views)
Also don't forget that xy-graphs accept complex arrays, simplifying the data structures even more. 🙂
(See e.g. this example.)
(4,160 Views)
