dsc module run-time system
Where can I find the DSC Module Run-Time System 7.1?  It doesn't appear to be on my disk, and the entry on the NI site under driver downloads doesn't have the file (http://joule.ni.com/nidu/cds/view/p/id/571/lang/en).
(3,166 Views)
Hi Charlie,
We generally support all software to two versions back from the latest version and that is also how we maintain our software. At present the earliest version we support is 8.0. I would suggest calling National Instruments through this link as you would need to have a license to install the DSC Run-Time. Even if you already do have the license you would still need to obtain the Run-Time through National Instruments. hope this helps!
Ipshita C.
(3,141 Views)
Here is the link I referred to in the previous post.
(3,140 Views)
Your link doesn't work.  Please send again.  Thanks.
(3,126 Views)
Here is the link again, Charlie. Hope this helps!
Ipshita C.
(3,119 Views)
