Exception occured in OraOLEDB: Accessor is not a parameter accessor. in NI_Database_API.lvlib:Rec Fetch Recordset Data (R).vi->NI_Database_API.lvlib:Rec Fetch Recordset Data (CR).vi->
I have a sql query that run directly in the database but when I attempt to run it in labview using the create_parameterized_query.vi I and fetch_recordset_data.vi get the following error:
Error -2147217845 occurred at NI_Database_API.lvlib:Rec Fetch Recordset Data (R).vi->NI_Database_API.lvlib:Rec Fetch Recordset Data (CR).vi
I've been using the tracer utility to try to see what the problem is but so far I haven't been able to figure out the problem.  I have several other tables in my database that I'm pulling data from and this same structure and they run without any problems.
 I'm enclosing my .vi
(11,260 Views)
Hi montyponty,
According to a Google search it looks like error  2147217845 shows up a couple of times with Oracle databases. Does the following page offer any helpful suggestions:
http://forums.devx.com/showthread.php?t=47596
From which VI does the error originate from? Can you post the other code that does work so we have a comparison?
Joshua B.
(11,233 Views)
thanks for your help.  I figured the problem out.  The date field had some data with the year 0007 instead of 2007.  Oracle didn't have a problem with this date, but Labview couldn't handle it.  problem solved.
(11,226 Views)
