draw table using report generation toolkit
Hi all
I have been trying to generate a table on MS word using report generation  toolkit (please see the attached word document for the layout for the table).
please help
i m using labview 9.0 with report generation tool kit
help
regrads
(4,483 Views)
what's the point we could help you?
You tried to generate a table in word, .... and ...
hey you generated a table in Word.
Maybe you could explain what the PROBLEM is.
Balze
(4,479 Views)
i want to generate it using the report generation tool kit via labview ..... the word document is for refference what the table should look like
regards
(4,455 Views)
OK, I understand,
and why don't you ? You've got a problem with htis, right?
What kind of problem do you have?
This task is pretty easy. (Please take care of the right values for you format.)
Balze
(4,444 Views)
There are several examples shipped with LabVIEW concerning Word and Excel :
C:\Program Files\National Instruments\LabVIEW 2010\examples\office
C:\Program Files\National Instruments\LabVIEW 2010\examples\comm\ExcelExamples.llb
C:\Program Files\National Instruments\LabVIEW 2010\examples\reports
Da Helmut
Voir le profil de Maxime M. sur LinkedIn - View Maxime M.'s profile on LinkedIn
(4,438 Views)
Accepted by nolsqn
Here is the code...
(4,436 Views)
In aboue code just add save vi and delete vi then all is done... It will give the output just exactly you have shown in Ur doc file...
pals
(4,427 Views)
