dll calling with LabView
I'm calling a DLL that uses structures as the
data type, I'm using Labview 5.1, but I don't
know how to define this type of data in the
LabView Dll datatype dialog. Does anybody can
help me?
Carlos
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,782 Views)
Hi Carlos,
> help me?
If there are pointers in the structures, you have to write
a interface DLL or CIN.
If not, you can build a string in labview containing the
data of the structure and pass it to the dll as pointer
to the string.
Martin
Martin Henz Systemtechnik
Dipl. Ing. (FH) Martin Henz
Walchensee Str. 3
70378 Stuttgart
Tel. ++49-711-5302605
Fax ++49-711-5058649
http://www.mhst.de
(3,782 Views)
You can select "adapt to type". Build a bundle with all the datatypes in the
structure and wire it to the dll. (save the vi, LabVIEW will crash if it
isn't exactly the same). This will work in most cases. Make sure the cluster
order is right. If the dll requires string pointers, you've got a problem...
Wiebe Walstra
AIR technical Automation
www.air.nl
wrote in message
news:8st6p0$s76$1@nnrp1.deja.com...
help me?
Carlos
Before you buy.
(3,782 Views)
You can write your DLL, include this dll, and to describe structure as single
elements in your DLL. This work in all cases.
Sorry for my English 🙂
> Regards,
> Wiebe Walstra
> www.air.nl
> wrote in message
> know how to de
> help me?
> Carlos
> Before you buy.
(3,782 Views)
Select the "Adapt to type" option. You can then wire a bundle to the dll.
Dll's requiring string pointers, cannot be handled this way. If you have
only one string, you can download the vi 'StringToPointer' from our
homepage. This causes problems if you need more stringpointers.
Wiebe Walstra.
www.air.nl
wrote in message
help me?
Carlos
Before you buy.
(3,782 Views)
