BUG in LabVIEW 6.0.i (Array Subset)
There's a bug in LabVIEW 6.0.i!
To make this bug visible, follow the next steps:
1 Create a 2D array constand of integers (I used I32, but it doesn't
matter).
2 Fill it with some values (e.g. 20X20 values).
3 Use Array Subset to pick the first index and length 4 (e.g. Array index=0,
Length=4,Array index=0, Length=4).
If you create an indicator, you'll get a 4X4 2D array.
4 Create another 2D array of dubbles. Fill it 3X3.
5 Multiply the result (the dubbles on the bottom of the multiply, the
integers below).
This results in a 3X3 2D array, as expected.
6 Insert a convert to dubble between the integer array and the Array Subset.
This still works fine.
7 Place a case structure around the integer array. It doesn
't matter if the
convert is in or out of the case.
The result is a 4X4 2D array, not a 3X3 2D array! Remove the convertion, and
it works fine. Switch the top and bottom of the multiply, and it works fine.
Remove the case, works fine...
Is this a bug, or what? It can produce some really unexpected results, and
it has in our case...
Wiebe Walstra.
AIR technical Automation
www.air.nl
(3,230 Views)
I see what you are talking about. Looks like a bug to me, too. Also
if you place the Array Subset in a case statement instead of around the
interger array and set it to the opposite case your final array created
has the number of elements as your interger array.
The only work around that seems successful is to place the convert
function *after* the Array Subset function.
eric
In article <972653638.6885.0.pluto.d4ee054f@news.demon.nl>,
"AIR Tech. Autom." wrote:
> Hi,
> matter).
ind
ex=0,
> integers below).
Subset.
> 7 Place a case structure around the integer array. It doesn't matter
if the
convertion, and
works fine.
results, and
> Wiebe Walstra.
> www.air.nl
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,230 Views)
Yep, looks like a bug!
> Hi,
> matter).
index=0,
> integers below).
Subset.
if the
convertion, and
works fine.
results, and
> Wiebe Walstra.
> www.air.nl
Before you buy.
(3,230 Views)
