Showing results forĀ
Search instead forĀ
Did you mean:Ā
display mutiple plot in waveform chart
I am using a waveform chart in which I want to plot multiple values in y axis  with time as X axis. But it is not displaying values. It shows 0 value plotting. Please help
(2,993 Views)
I am inputting 5 double values and one time value in bundle to a waveform reference
(2,991 Views)
Are those values supposed to be different plots?  If so, use the Build Waveform inside of a FOR loop to create an array of waveforms.  You can then write that to the chart.
And please use the terminal if at all possible.  It is a lot faster and easier to figure out.
And as an aside, you do not need to wire up all of the indexes for the Index Array.  It will default to the first element and increment automatically as it is dragged down.
(2,982 Views)
Thanks for  reply. I dont want to build waveform.
I am generating an array with 5 double values and a time (timestamp). I want to display it in waveform chart with time in X axis and 5 value in Y axis . I am adding the chart each one second with new set of values. Please help
(2,951 Views)
rakesh@labview wrote: I dont want to build waveform.
Really?  But, then you stated:
rakesh@labview wrote: I want to display it in waveform chart with time in X axis and 5 value in Y axis.
So you actually DO want to build up the array of waveforms EXACTLY how I showed you in my previous post.
And you might want to check out this nugget: Sporatic Waveform Chart
(2,942 Views)
