display every 5th element of the array
I am trying to take a for loop iteration and pull out every 5th element of data. This will eventually go to comparison of some type to activate a true/false case structure.
What I am having difficulty with is getting the algorithm down. I have attached a simple for loop that has a constant of 100 attached to the "N" terminal with a random number generator multiplied by 100, sending that through the for loop to give an array on the other side.
I will continue to rack my brain to see if I can solve this, but I have spent the better part of the morning trying to figure, and search this out, and have come up with nothing.
See attached vi.
Message 1 of 12
(4,686 Views)
Decimate array resized for five outputs?
Ben
Message 2 of 12
(4,683 Views)
You can use a couple of different methods to do this.  Have a look at the Decimate 1D Array and Quotient & Remainder functions.  I have attached a modifed version of your code.
Dan
Message 3 of 12
(4,682 Views)
Accepted by topic author M Boat
Message 4 of 12
(4,681 Views)
Maybe I was confusing in the initial post.
I am trying to use the iteration of the for loop to pull out every 5th element of the array. I am not even sure how to use the decimate array function.
Message 5 of 12
(4,674 Views)
Have you looked at my modified code?
Dan
Message 6 of 12
(4,665 Views)
yes, it seems to work. 🙂 I am working on some indexing issues of where it starts in my data. I will post up a screen shot here shortly.
Message 7 of 12
(4,660 Views)
Can you use this method. It was that Ben suggested I think
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 8 of 12
(4,654 Views)
Maybe something like this?
Message 9 of 12
(4,645 Views)
Here are some images of my code that your solution went into. I would just post the vi's, but my project has a gazillion vi's to it to run, and I am limited to 3 attachments. See below.
Like I said, it seems to be working but, I am having some indexing issues. Also, the lines that start out with "0.000" are supposed to be blank. Basically everywhere there is 0.000, I am trying to make go away. The data I need to be there is every multiple of 5, ie: 5,10, 15, 20, etc.. until it gets to the end of the data file.
Message 10 of 12
(4,640 Views)
