filtering
Is there any way to filter the string, I am trying to retransmit the signal
Message 1 of 8
(4,499 Views)
I do not have LabVIEW 2010..Can you post block diagram image?
Or code in LV09?
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 2 of 8
(4,489 Views)
I don't really understand what "string" you want to filter. Could you be more specific?
Anyhow, I think you wanted to add the noise to simulated signal and not to merge them. Take a look in the attachement.
Paulie
Message 3 of 8
(4,482 Views)
labview 9.0
Message 4 of 8
(4,451 Views)
It is still in LV2010. Smiley Sad
Gaurav k
CLD Certified !!!!!
Message 5 of 8
(4,432 Views)
Hi Naveen,
I am not quite sure what you are trying to filter here. Are you filtering a string, or the signal? I have looked at your code, and am still not quite sure what you are trying to accomplish.
Cheers!
TJ G
Message 6 of 8
(4,402 Views)
i tried to filter the string which is not possible, so i transmitted the signal twice and i found the output  is same
Message 7 of 8
(4,392 Views)
Hi Naveen,
I am still unsure as to what the question actually is. It looks like you successfully filtered the signal data. Trying to filter the string will give you the wrong data when you try to decrypt. Are you trying to transmit that string to another VI? are you trying to parse information in the string? What is your end goal here? Are you trying to generate/acquire a signal, filter and encrypt then send it? I just need more information on the problem before I can try to help you out.
Cheers!
TJ G
Message 8 of 8
(4,365 Views)
