different sampling rate for daq inputs
i am using daq card 9025.
i wish to take two inputs at different channels but with different sampling frequency..
cani do this using daq assistant ?
or i wud have to use traditional daqmx functions?
could anyone shelp me with one example?
(3,674 Views)
I would sample them both at the higher frequency, then decimate the data for the slower channel.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,666 Views)
A 9025 is a cRIO controller.  I don't think that is what you have.  Perhaps you meant a 9205, which is a 32 channel AI module.
All imputs from a single module will have to be read at the same rate.  If you want to run at different frequencies, you will need to have another module.  What I tend to do in similar situations is just read at the fastest rate needed and then just perform an average on the channels that should be at a slower rate.
(3,664 Views)
and what averaging function would that be?
(3,660 Views)
I typically used Mean.vi (does not get any simpler than that).
(3,655 Views)
