detection techniques
Hello wuliao23,
When an ROI is chosen on an image, the region includes all the pixels within it. The region can only be increased pixel by pixel both lengthwise and breadthwise; the border line of the ROI will not go 'through' a pixel. Once you set the pixel values outside the ROI to be a constant value, the pixel values within the ROI should remain the same as they were previously.
I hope I had understood your question correctly, and that this helps you out.
Vivek Nath
Machine Vision
Message 11 of 16
(1,019 Views)
thanks for reply..
i get the point...but i don know how to set the pixel value
outside the ROI as constant value and the pixel value
inside the ROI remain the same as previous.
may i know which module will deal with this kind of function?
thank you.
Message 12 of 16
(1,016 Views)
Hello wuliao23,
I have attached an image of the block diagram of a VI I setup. This VI enables the user to choose an ROI on an image, and then masks the ROI so as to set all pixels outside the ROI to black. If you need to set a different pixel value from black, you can try playing around with the 'Pixel Manipulation' functions.
I hope this helps.
Vivek Nath
Machine Vision
Message 13 of 16
(997 Views)
thank you very much...
i try to work with it...
Message 14 of 16
(989 Views)
hi...
if i wan to make it to suite for playing the avi file...
what is the things i need to modify?
thank for reply
Message 15 of 16
(979 Views)
hi...
i have solve the problem which can implement the method to avi file..
thank you..
Message 16 of 16
(976 Views)
