compare string name files
I have a VI that compare the numbers files in the folders. If the numbers files changes, he execute
a script in diadem else nothing.
I would replace this counter of files by a function that compare two string name of files.
For example:
1st name file acquisition :10-57-35-7-2-2008.acq
2nd name file acquisition : 5_10-57-35-7-2-2008.acq
I want just compare that is bold.
If that is in bold aren't identical, I would execute a script in diadem
I join VI of my application.
(3,271 Views)
Hi samosi,
could you try the attached vi?
The vi in the upper left is found in advanced file functions palette...
Message Edited by GerdW on 03-06-2008 04:02 PM
(3,261 Views)
Greetings. Is there a specific format to what's in bold? For example, is it always the same number of characters? Or, could you have 10-57-35-07-02-2008.acq? It seems that the month and day is formatted as a single character. One way to do this is to search the file name string for "-", and then take the text starting at 2 characters back, or the text that appears after the "_" if there's one there. A more explicit answer can be provided if you can provide more details on the format of the string.
A suggestion is attached.
(3,256 Views)
In attachment you have an example to perform this comparation. Let me know if it's ok for you.
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(3,254 Views)
Tip for previous example: You can just use the "offset of match" output with a <0 or >=0 Comparison function (depending on whether you want the indicator to indicate match or no match). Less code. Smiley Wink
(3,244 Views)
