lvrt.dll error in application
Hi, I have built an application from my development PC and I am running it on a target PC. The application crashes regulary on the target PC, within 20 min. Windows displays an error measage that states that lvrt.dll caused the failure. I have been searhing the forum for answers, and found other people with the same problem, however there were no clear solutions to the problem. Does anyone have a solution?
My labview version is 8.5.
My hardware is a CompactDAQ chasis, with modules 9472, 9265, 9205. Moreover I am reading out temperatures from an Agilent 34970A though a GPIB interface.
With kind regards,
Jesper
(3,835 Views)
Does your target PC has the LV run-time of the same version installed, without having LV itself?
Did you include the lvrt.dll in yopur build process?
Try these optins & update here...
- Partha ( CLD until Oct 2027 🙂 )
(3,826 Views)
Hi Partha,
Yes the target PC has labview runtime engine version 8.5. It does not have labview installed.
I did not include lvrt.dll in the build, how do I do that?
With kind regards,
Jesper
(3,822 Views)
I too have been experiencing this problem, only with 8.2.  I have a built application that crashes semi-randomly on my development machine - XP blames LVRT.DLL.  I bundled the 8.2 LVRT.DLL into my build as suggested, that didn't help.  The application thus far is just a fairly complicated GUI with no hardware being addressed (yet) and no external libraries being called (yet).
Insight, anyone?
Thanx.
(3,789 Views)
Hi, I solved my problem now. It turned out to be this error: http://forums.ni.com/ni/board/message?board.id=170&message.id=290093.
So emonk, maybe that will help in your case as well.
Cheers,
Jesper
(3,760 Views)
Hmmm...well, I'm not using any charts...I have a few listboxes but they don't do anything yet.  I might be the Dell hex.  Today I'm going to move it over to another machine and see what happens.
(3,748 Views)
