derivative problem
I tried to figure it out with a shift register and it also worked perfectely. Thank you so much @CARYA 😊
Message 11 of 14
(866 Views)
Accepted by topic author Ezzow
Since you are not interested in absolute times, (just time differences), I would substitute "high resolution relative seconds" (Simpler datatypes, no coercion dots, etc.) and a feedback node.
Note that you get a division by zero on the first iteration (that possibility exists even in your code!). You can program your way around thus but since you don't even initialize the upper shift register, it seems you don't really care.
(Of course since you do single point acquisition, you should probably run the loop at a defined loop rate. Then you don't even need to measure dt because you already know it.)
Message 12 of 14
(842 Views)
@altenbach
I really apreciate your help. I tried it with "high resolution relative seconds" and it worked properly 😉
Do you mean by using a wait function?
Message 13 of 14
(806 Views)
@Ezzow wrote:
@altenbach
Yes. Just make sure it is the determining factor, i.e. it is the slowest part of all loop code.
Message 14 of 14
(782 Views)
