delete files
I now just checked the error code. You want to write a property which was not yet created. So you want to write the listbox caption and the itemnames. If you rightclick the listbox and select visible, you'll see that caption is not selected. This must be the error - select caption and it should work.
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 21 of 23
(649 Views)
The attached modified VI has Label.Visible & Caption.Visible properties added.
ian
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 22 of 23
(645 Views)
Thank you very much to all.
Message 23 of 23
(633 Views)
