delete 0 from array
i tried this and i got an error with the while loop?
Message 11 of 25
(4,504 Views)
You don't have a while loop.  You have a For Loop.
Look at the tunnel on Mark's example where the array comes in.  It is an auto-indexing tunnel.  It passes in the elements of the array one at a time.
You used a regular tunnel which passes in the whole array.  Nothing is telling the For Loop how many times to run, and  you are always just indexing out the first (0th) element with the Index Array function.
Message 12 of 25
(4,500 Views)
There is no while loop.
Message 13 of 25
(4,499 Views)
i recieve the same problem?
Message 14 of 25
(4,493 Views)
What's in the true case?
(Please attach VIs instead of pictures!)
Message 15 of 25
(4,487 Views)
but this works!.
thanks
Message 16 of 25
(4,484 Views)
i got rid of the CONSTANTS ARRAY at the beginning of the for loop!
Message 17 of 25
(4,483 Views)
You need the array constant so that the shift register is initialized otherwise when you run this VI again, it will just tack onto the end of the previous results.
Your problem before is that your array was not empty, it had at least one zero value in it.
You need to drag the double value out of the array, then drag it back in.
Message 18 of 25
(4,479 Views)
ok.
i understand now.
thank you!
Message 19 of 25
(4,472 Views)
Hello
I try to delete rows where there is NaN in an array.
But the result is wrong.
Can you help me ?
Message 20 of 25
(2,052 Views)
