delete 0 from array
how do i delete the 0s from this array? Its been a while and I am still trying to learn how to do this. thanks
Message 1 of 25
(20,821 Views)
Just right click the element.  I think it's under data operations delete element.
Message 2 of 25
(20,816 Views)
Right Click on the element, go to data operations, choose delete.
Mark Ramsdale
Message 3 of 25
(20,812 Views)
i have another subvi that creates this array.
i just need to delete 0s somehow.
i need to write a loop to delete it but nothing seems to work
Message 4 of 25
(20,805 Views)
HINT: For Loop, case structure, build array, shift register, "Equal to 0?"
TailOfGon
Certified LabVIEW Architect 2013
Message 5 of 25
(20,795 Views)
Please post what you have tried.
I would recommend you look at the help files for "Search 1D Array" and "Delete from Array".
I would also recommend you do a forum search.
Message 6 of 25
(20,793 Views)
Accepted by topic author HelloKristy
here is a snippet to do that.  Copy to desktop and drag onto VI.
Mark Ramsdale
Message 7 of 25
(20,792 Views)
Do you only need to delete from the beginning (all up to the first non-zero value) or throughout the entire array?
If the former, use a for loop with the termination set to exit when a non-zero value is found.  Take the iteration, feed that into a subarray primitive.
If the latter, use the Search 1D Array function to find the 0s and Delete from Array to remove the elements.
Message 8 of 25
(20,787 Views)
Mark,  the appropriate function to use in 99% of the cases is Build Array, not Insert into Array.
Message 9 of 25
(20,777 Views)
Agreed, thanks for the reminder Smiley Happy
Mark Ramsdale
Message 10 of 25
(20,773 Views)
