define a data type (read binary file)
I want to read a EEG TRC file and am struggling with it's data type, i know that i can put a cluster in the input of data type on a "Read binary file", but i don't know how it actually works, her is what i have:
I have a definition of the TRC header file:
offset: 0, label: patient info, data type: char, description: patient data
offset: 32, label: recording info, data type: char, description: recording info
offset: 64, label: acquisition unit, data type: Unsigned long, description: type of device
etc...
Above is an example (fake one), because i can't give away the file structure description, from this specific file...
So my question is: how would you define a data type cluster that could read binary files and reads it like exactly that way?
Or does this only works with files saved as a labview structure? For example a cluster?
Thijs Boeree
Message 1 of 11
(7,663 Views)
I tried the thing in the attached file... But it doesn't work
regards,
Thijs
Message 2 of 11
(7,657 Views)
Hey Thijs,
Could you not just read it in as a text file and use string manipulation to get the parameters that you need? If you give me an example of the data you are trying to feed into the cluster I will give you an example.
Andy
_______________________________________
"To 'G' and not to 'C', this is not a question!"
Message 3 of 11
(7,650 Views)
Unflatten won't work like this, how would it know where to separate the input string into the different strings in your cluster?
You will have to split the string.
You can do this by reading the file in pieces (define number of bytes to read) and convert each piece into the corresponding data type, or you can read the whole file as string and then split and parse it.
Message 4 of 11
(7,645 Views)
Oke,
For example you can use the "constant" string in my attached vi in the original question and convert that to the cluster also in the VI this is the structure for the data:
Cluster
 32 char
 32 char
   cluster
     22 char
     20 char
     1 U8
     1 U8
     1 U8
Best regards
Message 5 of 11
(7,642 Views)
Hey Thijs,
So maybe you could use something like this:
Andy
Message 6 of 11
(7,634 Views)
Or like this:
Message 7 of 11
(7,627 Views)
Hi, i am on my way home now, so i'm going to check it first thing in the morning. I was thinking about it, and came to the conclusion that i maybe needed to make an array of a cluster with an offset, length (count) and diffrent data types and run that in a fror loop to instruct the read binary file and the 'set file position' to retrieve the data and than later on put these in a well defined cluster!
But maybe you have the same solution...
Message 8 of 11
(7,625 Views)
Accepted by ThijsBoeree
You can do that, but of course you can't auto-index different data types into one array. But you could populate the cluster directly in the for loop.
Message 9 of 11
(7,620 Views)
I was planning to make a case each with a different data type... and according to the data type in the cluster array it would switch to a different case... but we'll see!
Message 10 of 11
(7,614 Views)
