decode time stamp from c-code
Hi everybody,
I have a TCP/IP where I send datagrams (in c-code) to LabVIEW (which is the server).
The datagram sends with every data a time stamp in the following way: dd.mm.yyyy hh:mm:ss.zzz, where zzz stands for milliseconds. I would like to see my data in a waveform chart at the LabVIEW frontpanel, but I'm not sure how to get a continuous time stamp from the c-code. I tried it with "scan from string" (as my data enters LabVIEW as a string), and then I made a sum of the minutes (times 60) and the seconds, which works for one minute, but after one minute my time goes of course to zero again which isn't nice for the waveform chart...
Does anybody has a nice idea how to solve this? Any examples?
Thanks in advance!
Steffi
Message 1 of 9
(6,961 Views)
Hi steffi,
use "scan from string" with this format code: "%d.%d.%d %d:%d:%d.%d" to get all components from your timestamp.
And you can use "Date/Time to seconds" to form all those values into a valid LabView timestamp.
Added attachment to show all this...
Message Edited by GerdW on 02-01-2008 09:57 AM
Message 2 of 9
(6,957 Views)
This code should help you,
I only have a problem to read the final '.' my localization set the ',' as decimal sign and I can't get LabVIEW to change the decimal sign in this parser.
Ton
Message Edited by TonP on 02-01-2008 10:00 AM
Message Edited by TonP on 02-01-2008 10:01 AM
My LabVIEW Ideas
Message 3 of 9
(6,951 Views)
Hi TonP,
nice solution - I have to get used to time formatting codes too Smiley Wink
Have you tried to include "%,;" at the start of your format string? Does it help with time formats too? Oops, I see you already opened a new thread to discuss this...
Message Edited by GerdW on 02-01-2008 10:41 AM
Message 4 of 9
(6,939 Views)
What I do in these cases, create a timestamp control, and change the Display Format to match what I want (using advanced formatting) in that way I most likely get the correct string.
Ton
My LabVIEW Ideas
Message 5 of 9
(6,933 Views)
Hello GerdW and TonP,
thank you very much for your help.
Unfortunately I can't open your vi, GerdW, as I only have LabVIEW 7.1. Maybe you can post it for 7.1 again? I don't know what type of the output I have to choose (right now I have U32 and I can't use the "Date/Time to seconds").
What default value did you set, TonP? When I tried your solution, LabVIEW says that I have too many format specifiers in my "scan from string"? Do you have an idea what my mistake is? And I can't create a constant at the output as I didn't set a default I guess.
Thank you very much,
Steffi
Message 6 of 9
(6,913 Views)
Hi steffi,
you should have told us before which LV version you use...
Try to use the solution described in my first message, I will try to add an example in LV71 later.
Message 7 of 9
(6,910 Views)
Hi steffi,
here's a LV7.1 version...
Message 8 of 9
(6,899 Views)
My code won't work in LV 7.x, the %<xxx>T is introduced in LabVIEW 8.0 if I'm correct.
Ton
My LabVIEW Ideas
Message 9 of 9
(6,881 Views)
