data logging
I am acquiring 4 channels simultanteously with USB-9126 running with Con't Acq&Graph Voltage-To file (binary).VI and I can see all the 4 channels from the display. Can someone explain to me that why am I getting data that consists of sometimes more than 30 rows?
(3,772 Views)
Sorry, could not really understand your query
Do you mean that the output of DAQmx read (which gives a 2D array of data), has more that 30 rows of data??
If you observe,  there is a tranpose function in that vi before the data is written to file
maybe you are looking at the 2D data after it is transposed. In  which case, it will have 4 columns and 'n' rows ( where n = number of samples to read per channel)
(3,772 Views)
I am acquiring 4 channels simultanteously with USB-9126 running with Con't Acq&Graph Voltage-To file (binary).VI and I can see all the 4 channels from the display after they are transposed by the transpose VI. They look right. There are 4 channels as they should be. Can someone explain to me that why am the data I am saving consists of sometimes more than 30 or more than hundred rows (There are like 10000 colums as well)?
(3,739 Views)
You are saving data in binary format. How are you reading the file? Opening up the file in Notepad or Excel will not work. You need to run the Display Acq'd File (binary) in order to read it.
(3,730 Views)
him,
you seem to be running 2 threads on the same query.
I recommend that you stick to just one thread
This will help us to follow up and answer your queries effectively
(3,707 Views)
