data logging
I am acquiring 4 channels simultanteously with USB-9126 running with Con't Acq&Graph Voltage-To file (binary).VI and I can see all the 4 channels from the display after they are transposed by the transpose VI. There are 4 channels as they should be. Can someone explain to me that why am I saving data that consists of sometimes more than 30 or more than hundred rows ?
(3,004 Views)
I suggest you stick to one thread for your queries
You better continue in this link
This will make follow up a lot more easier
(2,999 Views)
I am acquiring 4 channels simultanteously with USB-9126 running with Con't Acq&Graph Voltage-To file (binary).VI and I can see all the 4 channels from the display after they are transposed by the transpose VI. They look right. There are 4 channels as they should be. Can someone explain to me that why am the data I am saving consists of sometimes more than 30 or more than hundred rows (There are like 10000 colums as well)?
(2,978 Views)
How are you seeing this data??
are you using the example vi 'Graph Acquired Binary Data.vi' to read the binary file saved by 'Cont Acq&Graph Voltage-To File(Binary).vi'??
(2,968 Views)
