data is transfering via VISA write, but different values are coming
i am giving 5 bytes of data, data is transfering into VISA write operation but at output side different values are getting,
    how can i reslove my problem,
i given a screen shot of my VI please gothrough it,
   please sugguest  me.
Message 1 of 10
(3,449 Views)
You're not sending 5 bytes. You're sending 5 integers converted to a string. That string is much longer.
We can't say much else about it, as you've given us just a small peace of the puzzle.
Post the code. Also the receiver end.
Why a while loop polling the Stop button if you already have an event structure? Add a Stop value change event, and put the integers and the conversion there...
Message 2 of 10
(3,437 Views)
in VISA read operation data is not transfering continuously ,i am using event structure for event changing the events are "visa read " and "visa write" operation,
i am using case structure for VISA read operation,
my issue is VISA read operation in case structure , the structure is not  running continuously
please sugggest me
im placeing my VI please go through it,
thanking you.
Message 3 of 10
(3,421 Views)
Hi saikranbusharaju,
Don't place that VISARead function inside a case structure inside an event structure to have it called continuously…
Btw. when is your event called? "READ" seems to be an indicator and no control usable by your users.
No, you just attached an image. There is no VI available to us…
Did you note wiebe's request in message #2? Please post the code!
Message 4 of 10
(3,409 Views)
its my VI . please go through it
 thanking you .
Message 5 of 10
(3,393 Views)
hi sir\ma'am
  its my VI please go through it once
 i wanting for your reply.
Message 6 of 10
(3,390 Views)
Accepted by topic author saikiranbusharaju
You've put typical event stuff outside the event structure, and typical non-event structure things in the event structure.
I'm actually not sure how you get this to do anything useful at all...
Perhaps someone else has something meaningful to say, but most advice will come down to "do some courses" or "here's my completely different solution for you".
Message 7 of 10
(3,388 Views)
@saikiranbusharaju wrote:
hi sir\ma'am
A response time of a few hours to a few days is pretty normal...
Message 8 of 10
(3,386 Views)
Hi  sir\ma'am,
      can you please modify my code,my application is i have to transfer the data continuously and user want to operate the process , i done little work and i am trying its,
can you suguest me (or) can you modify my code ,
   i'm sending my VI ,please go through it,
  thanking you.
regards
saikiran busharaju
Message 9 of 10
(3,379 Views)
None of us are going to modify your code. Put in the effort first. If your stuck, post your modified code to us and we can offer suggestions.
Message 10 of 10
(3,352 Views)
