08-24-2005 11:45 AM
08-24-2005 11:57 AM
08-24-2005 12:00 PM
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.08-24-2005 12:13 PM
Hello Ed,
Thanks for the reply.
I created the attached VI and saved it to the user.lib directory. Then, I inserted that VI on another VI diagram (Functions Palete -> Select a VI and choose select_channel.vi in the open dialog box) .
What do you mean by the subpanel feature of Labview? Also, what do you mean by recreating the subVI on the top level panel?
In My Application, I will probably have a main panel that opens the select_channel.vi's panel when the user pushes a button (named "select channels").
Steve
08-24-2005 01:07 PM
