How to call another program from LabVIEW?
Hi!
Is there anyone that can answer my question? I have found a similar thread where the user needed to call labVIEW from some program but I want to do the opposite.
I made a program in labVIEW that communicates via COM-ports (serial communication) with the processor I use at the job (Ubicom´s IP2022).
Now I want to add more funcionality to this program. I want to be able to program re-program IP2022 through this LabVIEW application.
The programming is done via an Ethernet-dongle. I start a program called IP2kProg, I write the ip-address of the dongle and the program-file (.elf) downloads at this address. But how can I do this from
LabVIEW, do I need to open IP2kProg or can I send some values to it via LabViEW?
Ant suggestions?
Thanks, Amir
(3,055 Views)
Amir,
There are couple of options:
1.  If your IP2kProg program has a command-line interface, you can use LabVIEW's System Exec.vi and send the commands and parameters to it.
2.  If the IP2kProg has an API / exported functions, you can call them from LabVIEW using the Call Library Function Node.
Hope this gives you some ideas.
-Khalid
(3,039 Views)
