real time display array
The test is generating 2D array (by loop). I have a array indicator on the panel, but not until the end of the test, I won't be able to see the array. How can I real-time display the array?
Message 1 of 17
(4,920 Views)
Can you post your code, there are several possible solutions, but they all in one way or another involve moving the terminal for the indicator inside the loop.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 17
(4,916 Views)
Message 3 of 17
(4,907 Views)
First, produce a version of your application that has as few subVIs as possible, but still demonstrates the problem you are having.
Next, when you go to send the message, at the bottom of the message entry screen you'll see an area to define an "Attachment" for the message. Click on the browse button and in the resulting dialog box find your VI. Select the name of your VI and click the "Open" button. The path to your file should appear in the space next to the Browse button. When you send the message, the browser will send your file as an attachment to the message.
If your VI has any significant subVIs, you will want to firts create a zip file containing your VI and the subVIs and attach the zip file to the message.
Mike...
LabVIEW Champion
Message 4 of 17
(4,901 Views)
Under the grey box where you type and format your message is a text field called "Attachment".  Click on the "Browse" button to find the file on your computer.
If your code has a lot of sub VIs, make sure you include them in the saved file.  (Save With Options->Development Distribution)
Message 5 of 17
(4,899 Views)
Message 6 of 17
(4,892 Views)
I'm sure Mike has a more elegant solution, but the one attached will work.  The new version is on top, your old version is on the bottom.
Message 7 of 17
(4,887 Views)
a small note. Smiley Wink
The inbond shift register is unused so the aquired data will not be appended to the previous data.
Jack
Win XP
LabVIEW 6.1, 7.0, 7.1, LabWindows/ CVI 7.1
Let us speek Russian 🙂
Message 8 of 17
(4,879 Views)
Oops, you're right.  Sorry 'bout that mistake.  I'm at work so I'm trying to do things in a hurry!  Thanks for pointing that out
Message 9 of 17
(4,874 Views)
Message 10 of 17
(4,865 Views)
